cloud9
Gary
Good deal Tracy. I will say FR's customer service is unmatched in the industry.
cloud9 said:Good deal Tracy. I will say FR's customer service is unmatched in the industry.
fuhrius said:And that was good enough for me.
for me too. I'm a sucker for huge R&D departments ;-)
I've also tried to sway toward ford stuff for as many of the mods as I can...so that's part of it too.
while my car will never see a drag strip and has yet to see a track, I opted to have the relo brackets welded in for extra peace of mind. I don't see the harm, though I agree with folks' assessments that it's not necessary for anything other than extreme drag racing.
ArizonaGT said:The FRPP brackets do not require welding, they are only bolted-in from the factory on the 302S cars.
If I were drag racing, I would go ahead and weld them in. I was told by BMR that their LCA brackets don't have to be welded in for road racing but if I was going to drag race, specifically with slicks, I should consider welding them.808Boss said:So it would be ok to use with frpp relocation brackets just bolted in (without welding) to do some drag racing with slicks? I've heard that the relocation brackets should be welded in for drag racing, especially if I'm lowered with the p-springs...Just want to clarify that part..
That's what I have been told as well and what I did on my GT500 when I was drag racing it.LindsayEOD said:If I were drag racing, I would go ahead and weld them in. I was told by BMR that their LCA brackets don't have to be welded in for road racing but if I was going to drag race, specifically with slicks, I should consider welding them.
They're not and FR recommends welding in the brackets if you're going to be drag racing and using slicks.Justin said:Every other set I have seen requires or recommends welding them in if drag racing with slicks is to be done. I dont know why the ford racing parts would be any different unless they are made of the unobtainium lol
TMSBOSS said:Suggestion
Take the bolt with you to a hardware or automotive parts store. Buy grade 8 flat washers to fill the gap. Instsall the washers equally on both sides of the car and the sleeve as needed.
Torque and drive.
I had a issue with FRPP LCAs which were manufactured wrong. I filled the gap with washers until receiving replacements from Ford directly. Yes, this is one reason I stick with Ford parts. THe fix their issues.
Tob said:I added the FRPP Relocation Brackets to my S197 pig and noticed a similar discrepancy. My stock arm looked something like the following before the bracket was installed...
Look at the above carefully. Cinching the bracket inward via tightening the LCA bolt brings the two faces out of square. Using a washer(s) is your best bet. I verified that the stock arm width at the rear matched the MM Extreme Duty arms I have been using...
