Let’s see your Heat extraction / Hood vents
racer47
Still winning after 30+ years
392
497
SE WI
07-09 GT500 hood with Trackspec vents, very effective but still good looking and kind of stockishhood.jpg
San Diego
Good call on the mesh. Mine have had the paint on the inside beat up in the first session after install
Wow the color match on your vents look great though! My car is black with black wheels, so the vents kinda blend in color wise.
Once again these are the new RSF top curved fender vents, so the redesigned ones that just came out. Just sent Al at Race Louvers the base photos since there aren't any on their site yet.
Car already felt noticeably more stable up front, can't wait to get some track time with these to properly gauge the difference.
I have track spec side vents to go on my 2016 and am considering a center vent.
What is the main difference between the Trackspec and Race Louvers center vent? Or should I stock with one mfg?
Car is primarily a CAMC autocross car (yes aero for autocross works), but I do drive on the street in Hiuston summers and occasional DE.
ChrisM
Mostly harmless.
1,180
1,420
South Carolina
Race Louvers have a built-in wicker bill on the front that makes them significantly more effective.
The biggest issue with side hood vents for the 15-17s is the front half of the vent is forward of the radiator including trackspecs and we know from wind tunnel testing venting a hood needs to be behind the radiator for good airflow thru the rad. Our Race Louver kits have a blank panel built into the front to make sure the louvers blades are shifted rearward and properly positioned aft of the radiator. So its highly likely your trackspecs arent functioning at all so you may want to upgrade them. Also if you look at any of our wind tunnel data the 'recessed' louver we use for reference testing is in fact the trackspec part and ours are clearly much better functioning. So you might consider new sides and center as we currently have 15% off for black friday / cyber monday.
So the RS side vents and center vent? Are they sold in a package?
ChrisM
Mostly harmless.
1,180
1,420
South Carolina
Added the GT4 center hood vent to my stock hood. A little nerve-wracking making the first cut...
Looks great! I understand the nerve-wracking part. I've got a set of Race Louvers sitting in my garage for a few months now while I steel myself to cut the hood. I owe Al some pictures of it when I'm done, though I'm wondering if I should exchange the RS type for the RT type.
Frank.JD.Perez
FJD Performance
314
490
Pleasanton/Hayward, CA
old factory hood with gt500 vent and some modification
gr40 fiberglass hood
Trackspec vents. Cannot have enough vent area to let out the heat. I wish the center vent was longer and closer to the cowl like as long as the side hood vents. I would like to know if these three vents are as effective as the Tiger/Chicane23 vented hood. I have thought about changing the hood but that would be about $2K all in and painted.
6,553
8,204
You don't wanna get too close to the cowl, there is a high pressure area at the base of the windshield that will force air into the louvers defeating their purpose. If anything, you want to get closer to the nose. Ideally the louvers should start right at the back of the radiator. That's actually quite a bit of vent area on that hood. A small wicker would help with efficiency.
Heres Trackspec vs Race Louvers: https://racelouvers.com/content/Race-Louvers-Wicker-Gurney-Flap-Raised-Louver-Wind-Tunnel-Data.pdf
Heres Tiger vs Race Louvers: https://racelouvers.com/content/Race-Louvers-Mustang-Hood-Shootout-Wind-Tunnel-Data.pdf
Basically tiger and trackspec operate about the same, but our Race Louvers are about double so I wouldnt go out a buy any cf hood unless its about the carbon thing..
Thanks Fabman - I think I will fab up a couple wickers of various heights for the leading edge of the vents and try them out.
