Paul@PAE
Supporting Vendor
- 33
- 56
AJ, what is the height at the leading edge and AOA for the splitter data you have provided?
I would get one for my 2011 boss front end in a heartbeat. I would even be willing to replace my from bumper to be able to use one. AJ, any plans on something of this nature for 2011 2012 boss Front end?
3" Static ride height, 0 AOA. We'll be posting data in a blog post at 3",2",1" ride heights and +1 +0.5 -0.5 and -1 deg pitch on certain iterations of Crusher (there were 15 iterations in total, and we narrowed down the promising candidates and then did the pitch and ride height work).
Yes, the splitters are being manufactured in modules, such that a side impact will take out a set of tunnels, but not the entire splitter. The important bit of the splitter is the leading edge, tunnels, flaps, and slots. We plan to make a version for the 05-09 Mustangs, and from there it's just a matter of a different airdam to "kiss" the top of the splitter from the bumper. Would you be going for the AI legal one, or the insane ST one? Just curious, since we are working on the ST one right now ahead of the AI version.
AI version. I have a different radiator support and brace, so my splitter goes all the way to the rear of the front axle.
Sounds like a good candidate for a prototype part. You car would really make good use of one.
The tough bit about manufacturing splitters is they are easily damaged. Our wing kits sell pretty well because for the most part, you buy it once and you are set. A splitter though, you can potentially be replacing it after every off track excursion. So just from that alone, even if we developed the most badass splitter ever, a cost would come with it that most people wouldn't be able to justify. And since we are a business, we need to be able to sell products that work, not just make something that looks cool for fun. But yes, once we finalize our CFD, the parts will be available for anyone.
Regarding simple flat splitters made from plywood, aluminum, carbon fiber, or any other material, they will never perform as well as a splitter with tunnel elements, a properly designed leading edge, end plates and slots to deal with the vortices, and attention given to the canard interaction. ...
It was designed by Kyle Drives at JKF aero and was the last project he worked on before being hired by Mercedes F1. So I'll take it that he knew what he was doing when he designed it and ran the tunnels how he did.Front diffuser angle looks optimistically aggressive.
Look how far away from the body these S550 mirrors are compared to the S197. That is no accident.
Somehow I don't think you're guessing and welcome to TMO. How's the track scene in Singapore? Any opportunities to drive the F1 track in the Marina when they close it down for the race in September?It's not just about drag.. Don't discount the aeroacoustics factor. OEM's spend tons of CFD time to optimize the A-pillar and mirrors for wind rush noise abatement due to the flow separation and it's "beating" against the window, and it's proximity to the driver & passengers ear. To solve this they have to use LES equations where they model and solve nearly all of the turbulent flow, rather than the RANS equations used for "regular" CFD. The compute time required for LES is an order of magnitude of that for the NS equations.
I recently ran some CFD on an 05-09 S197, stock ride height, factory rear spoiler, and removing the side mirrors took roughly 0.04 Cd off the total drag coefficient which was 0.492525, so about 8%. I think there are minimal gains by resizing the mirrors, so it's likely a decision made for NVH and a little drag side benefit.. Just a guess, though.
Convertible? That Cd is a little high for a coupe.It's not just about drag.. Don't discount the aeroacoustics factor. OEM's spend tons of CFD time to optimize the A-pillar and mirrors for wind rush noise abatement due to the flow separation and it's "beating" against the window, and it's proximity to the driver & passengers ear. To solve this they have to use LES equations where they model and solve nearly all of the turbulent flow, rather than the RANS equations used for "regular" CFD. The compute time required for LES is an order of magnitude of that for the NS equations.
