Wow. That's a bit of bad luck you've been running into...
Grant 302 said:Wow. That's a bit of bad luck you've been running into...
thehueypilot said:I only have bad luck when I let other people work on my car. I guess I have standards and they don't?
Tim
302 Hi Pro said:That scratching is terrible and sorry that happened to you. Glad to hear that they will refund your bill and pay for the refinish of your shock tower.
Looking at the second pic of your camber plate, I see that MM name tag does this have a function? Also do you get much of a Caster adjustment with the MM plates?
I went with the Steeda HD Camber Plates as I only wanted the Camber adjustment, but came close to buying the MM plates.
Thanks
Dave
302 Hi Pro
302 Hi Pro said:Looking at the second pic of your camber plate, I see that MM name tag does this have a function? Also do you get much of a Caster adjustment with the MM plates?
Domestic Product said:Totally unacceptable , make them fix it or pay to do so and never go back.
