Where does it plug in?
The OBD port is at the bottom of the dash to the left of the steering column, straight down from the light switch.seca954 said:Where does it plug in?
PeteInCT said:
dabossinne said:The OBD port is at the bottom of the dash to the left of the steering column, straight down from the light switch.
thats not smoke. thats water vapor nothing to worry about.sadil said:Video of my car idling this evening after a 15 minute aggressive drive. Its 2 degrees C outside, so about 35F. Car's exhaust is pretty much straight through with the no cats, LT headers, and over-axle pipes. Is this amount of smoke normal under a cold environment idle using the TracKey? Anyone else have this much smoke? Dont notice any weird smells, oil level is normal, and coolant is sitting an inch below cold fill range, and has been for a while.
P.S. I think it sounds totally awesome!
http://www.youtube.com/watch?feature=player_detailpage&v=XjnrwuGqRsE
below 60 I get the condensation smoke all the time at idle.PeteInCT said:Condensation after a 15 minute aggressive drive? Maybe....
oh you would know if you were burning coolant its easy to smell. and oil smoke is typically blueish in color and is easy to smell as well.sadil said:Yea, I have tried placing my hand in the exhaust air and it gets coated in water vapour and has a gas-ish smell to it. Don't smell anything out of the ordinary, then again I don't entirely know what to expect. I thought oil burning or coolant smell would be striking.
