- 70
- 0
A friend of mine is selling a pair of Michelin Super Sports 305/20/r19's. Would these fit my stock rims of my '12 Boss?
5 DOT 0 said:If you're referring to 305/30/19 then nope. You need to follow the manufacturers recommendations.
This. Read the specs at the link I posted.12BossKB said:the 305's are too wide for the 9.5" rim?
5 DOT 0 said:This. Read the specs at the link I posted.12BossKB said:the 305's are too wide for the 9.5" rim?
5 DOT 0 said:Well if the manufacturers minimum rim width of 10.5" isn't good enough for you then by all means use them. They won't rub if that's what you want to know.
I'd be all over them in a second. You can run the 255/35/19 and 295/30/19's, which are an inch lower in height, on the track but I don't want to run shorter tires on the street.Tflong24 said:I would love to get the super sports, but no luck on correct sizing for our cars.
5 DOT 0 said:I'd be all over them in a second. You can run the 255/35/19 and 295/30/19's, which are an inch lower in height, on the track but I don't want to run shorter tires on the street.Tflong24 said:I would love to get the super sports, but no luck on correct sizing for our cars.
