Measuring Pinion Angle
All,
Since this topic comes up frequently, what is the correct procedure for measuring pinion angle? Any different with a 2-piece drive shaft v. 1-piece?
Thanks
r/
Eric
1,022
97
Texas
I hope someone chimes in as I have been wondering the same thing. I will have to set my pinion angle after I install all of my mods. I have the upper control arm relocations bracket and adj upper control arm so I can set the pinion angle after I install the Eibach Sportlines. Seems like it shouldn't be too difficult I hope. That's wishful thinking :)
pufferfish
Supporting Vendor
1,094
66
Maryland
If you hang tight for a few weeks, I am going to do a write up on installing the dynotech 1 piece driveshaft, including setting pinion angle.
