Ultrakla$$ic said:Thanks for moving this.
Can't wait to get this shifter!!!
Thanks George for the awesome product!!!
Calif boss302 said:Hey Ultra keep us posted when you get it. I'm interested on the install difficulty level for an average Joe (or Bob) on ramps in the garage.
Ultrakla$$ic said:Here is the youtube video from MGW regarding the Gen3 RACE SPEC shifter:
[YOUTUBE]jdlpP0LDpkk[/YOUTUBE]
I started taking out the older MGW shifter, making a way for the new MGW Gen3 RACE SPEC shifter headed my way. Here is a pic of this behemoth of mechanical engineering:
First let me say you better pray you have small hands. Fat handed folks are going to be in a bind. LOL
You will HAVE to lower the transmission to get to this 10mm bolt here. NO OTHER WAY AROUND IT!!!!!
I used and old scissor jack and a piece of 2x4 to shim the transmission and hold it in a lowered position while I removed that bolt.
To get the little noise suppressant "cup" out of the shifter linkage arm I used a small screwdriver and pryed/worked it out from the BOTTOM of the cup, like so:
You can do it like the MGW video describes by grabbing it by the little holes but I'm gonna say there are going to be ALOT of destroyed plastic cups by doing it that way if you do not handle it tediously like MGW suggests. . The way I did it kept the little cup from tearing along the thin plastic that runs across the top of the cup that was suggested for prying on.
Cup is out with ZERO evidence of distress on the thin plastic around the holes:
My shifter will be here Monday so I'll finish the install then.:clap:
Ultrakla$$ic said:All buttoned up from underneath. Tip: when it comes time to put the shifter box in place and bolt it up to the linkages, access it' s position from INSIDE the car and drop it down through the hole in the floorboard. Don't even try to work it around the driveshaft and in place, just go inside the car and drop it down through the hole.
THIS setup seems like it's going to be the ABSOLUTE answer. I'm not adding anything to this setup at all. MGW RACE SPEC shifter and that's it. No bracket, no bushings, no nothing.
Calif boss302 said:Very cool . . . have you had a chance to road test yet? Remind us did you have the MGW or stock shifter before this new version??
WinterSucks said:I would definitely install the Whiteline trans mount bushing and urethane engine mounts if you are going to install one of these. Otherwise all the stress from the transmission and engine moving in the squishy mounts will transfer to the shifter support arm and mounting points since you still bolt the shifter box to the chassis. Pairing this with a new version of the BR bracket would probably be ultimate solution. It pisses me off that we even have to invest so much time and money to prevent transmission damage caused by them catering to NVH nannies. Just to drive the car as intended...
Ultrakla$$ic said:
Ultrakla$$ic said:I've yet to drive it because I'm taking pics and reporting as I actually finish the install. LOL
