Michelin Tire Tech Presentation by Michelin's Steve Calder for PCA
1,249
1,243
In the V6L
I've been looking for years to get some real information about the best tire pressures and temperatures for MPSC2's. There's a Michelin document that's easy to find for the original Sport Cup tires, but not for the SC2's. Until now...
This popped up in a Google search today: https://www.pca.org/sites/default/files/Michelin-Tire-Technology-Steve-Calder-TTW-2018.pdf
Pages 23-24-25 have the details from Michelin for the MPSC2 in track use. Finally!
The rest of the presentation has a lot of interesting stuff too.
1,249
1,243
In the V6L
The key data from the presentation reads like this (I removed the non-track stuff and disclaimers):
RECOMMENDED PRESSURE – SPORT CUP 2
TRACK USE – HOT TIRES
• The best operating pressure of MICHELIN PILOT SPORT CUP 2 is between 2.3 bar (33 psi) and 2.7 bar (39 psi) hot, according vehicle model and track where used
TRACK USE – COLD TIRES
• Don’t ever use inflation pressure below 1.9 bar (28 psi) cold and to optimize the track longevity of MICHELIN PILOT SPORT CUP 2, MICHELIN strongly recommends a minimum inflation pressure between 2.0 (29 psi) and 2.4 bar (35 psi)
RECOMMENDED ALIGNMENT – SPORT CUP 2
– Camber : for optimal results on a circuit , the negative camber settings should be between -1.5° & -3° dependent upon the circuit layout and the type of vehicle. NEVER exceed -4° of negative camber
Temperature Targets for Track Use
160 - grip starts to come in
180 - optimal temp for max grip
200 - grip begins to fall off
use a probe thermocouple – non-contact will read inaccurately
Note: for the 2019 MY GT350 and R, Ford's Owner's Supplement says hot tire pressures for track use - 38 PSI front, 36 PSI rear. Consistent with the Michelin recommendations. Much higher than I've been running though - I'll have to try them and see how it drives.
