- 6,400
- 8,288
As you are no doubt aware, PWC has hung 75 pounds onto our car along with the 52mm intake restrictor, I can only assume we'll be chaining Kias to our back bumpers next. In any case Dean Martin was pretty hooked up finishing 2nd on Friday and 3rd on Saturday. Phoenix was fortunate enough to finish 3rd and 5th on Friday, 7th and 8th on Saturday, It was pretty obvious that the restrictions were killing the mustangs, you could drive into the corners and the Astons and Porsches..not quite so much with the Camaros, would pull us down the straights, so essentially you got balked in the corners and couldn't build enough steam to pass at the end of the straight. Camaro I think won Friday, Aston on Saturday....we did keep the point lead, Martin in and his mustang is right behind us and it looks like Ford will pretty much lock up the manufacturer's championship shortly.
Basically, unless you pull some magic start out of your hat, you end up where you start, the Porsche broke on the line (and on the pole) Friday, that helped and a couple of cars got frisky and went off later. Saturdays race was not much, although Martin drove his rear end off to keep the 2 Camaros behind him, it was apparent, if they did get around, they would've pulled away. In the end, all the mustangs were running about the same lap times. Also as a not Gigliotti brake checked Kurt right at the finish line on Saturday and was fined and put on probation...nice. We had already lost a car on Thursday so we have no backups at this time.
