Mishimoto Oil cooler
The Setrab 948 is a GREAT cooler! Ideal oil temps? I think if you can operate over 185F and under 250F, it would be ideal. If you are consistently under 185 (not too likely in a race car but for a dual-purpose car, you can get there), then you need a thermostat to help get the oil temps up to "normal" viscosity and to burn off any H2O that may have accumulated.
jpt3 said:
Great info guys. I ended up installing a setrab 948. The thing is a monster. I ran at Watkins glen the other week. Granted it was pretty cold especially in the mornings but the oil coming back from the cooler never went above 220 and that was at the highest. In the am sessions it didn't even get to 200.
What do you guys feel an ideal operating oil temperature is?
Jake
The 948 has a fan pack available for it. You want your oil to get warm enough to vaporize condensation so the pcv can suck it up.
206
30
Makes sense guys. I do have a thermostat that is supposed to open at 165. I think what I'll do this winter is change the temperature probe to read from the side before it goes to the cooler to determine more accurately what's going on in the motor.
680
215
I'm really surprised at the amount of concern with getting the oil warm on street vehicles. The installation of an air to oil cooler didn't effect oil warm up on my boss at all. It did however have a serious effect on keeping oil temps in check. The cooler and a radiator enclosure have the biggest impact on keeping oil at optimum temp. Honestly, coyote motors have zero issues with bringing oil up to temp from a cold start.
This will be true if you kept your OEM oil-to-water cooler and ran the oil-to-air cooler in series. The OEM cooler also serves to rapidly warm the oil and it is relatively effective. In cold climates, however, we would still recommend a thermostatic control.... and we would DEFINITELY recommend a thermostat if the OEM cooler was eliminated.
I installed a boss 302 oil to water cooler in series with the Mishimoto air/oil cooler. I do not have an oil temp sensor to report the oil temps. What I do know is the Mishimoto sandwich plate does not work with the 302 cooler because the o-ring diameter is incorrect and with the stacked height of both coolers, the stock oil filter contacts the subframe. I used a Moroso sandwich adapter instead and a shorter oil filter Mobile 1 #m1-113. Also the line routing from sandwich plate to heat exchanger was not illustrated in the poor instructions. Mishimoto customer support wasn't very helpful with my questions.
I think with the 2 coolers combined in series with the addition of my Mishimoto radiator, the cooling should be sufficient for 20min track sessions.
I would do the Mishimoto rad again (effective and cheap), but not the oil cooler.
*edited for clarity*
smallblock said:
I installed a boss 302 oil to water cooler in series with the Mishimoto air/oil cooler. I do not have an oil temp sensor to report the oil temps. What I will say is the Mishimoto sandwich plate does not work with the 302 cooler because the o-ring diameter is incorrect and the stacked height makes the oil filter contact the subframe. I used a Moroso sandwich adapter instead and a shorter oil filter Mobile 1 m1-113. Also the line routing was a mystery, not illustrated in the poor instructions. Mishimoto customer support wasn't very helpful with my questions.
I think with the 2 coolers combined in series with the addition of my Mishimoto radiator, the cooling is sufficient for 20min track sessions.
06mach1 was one of the first to report that the Mishimoto sandwich gasket did not fit the Boss cooler well. I suspect that their kit was simply not designed with the Boss cooler in place, so it's no wonder they'd have no idea where to route the lines that way.
With the Moroso sandwich on top, I can fit the stock FL-500S oil filters but not the larger FL-820 Ford Racing ones.
Here's my hose routing for anyone installing the Mishimoto oil cooler. I notched out an area of the removable service splash shield under the car for a direct route to the sandwich plate. Before I buttoned it up, I covered any points of contact with rubber heater hose to prevent chaffing (not shown):
31937081383_3b409525ce_z.jpg by smallblock, on Flickr
32597804962_ec642494c1_z.jpg Mishimoto oil cooler by smallblock, on Flickr
32371052570_27b5cadcf7_k.jpg Mishimoto oil cooler by smallblock, on Flickr
Looks like there's enough line to go around the other side. Some of us went toward the passenger side with the Boss cooler. I tried for a while to get a clean shot on the driver side.
My install (in Removing the Stock Oil Cooler, what is needed? thread):
https://trackmustangsonline.com/index.php?topic=7462.msg113638#msg113638
More oil cooler install info here:
https://trackmustangsonline.com/index.php?topic=6652.0
206
30
I also went to the passenger side.
When I'm feeling motivated, I'm going to reroute mine to the pass side similar to yours. At the time it didn't look possible with the length of hoses I got and I was rushed to get to a track event a day later. Typical! Lol
