I had the MM Caster/Camber plates installed today and have some questions to any of you guys that have installed them. Cavet is that I’ve not hogged the holes for the camber bolts at all. For my install, I’ve been told that the most camber they were able to get (and keep both sides equal) was -1.7 degrees. My assumption was that I should be able to get at least -2.4 degrees. My questions are:
Also, if -1.7 degrees is all that I will be able to get do you have any opinions on how much benefit I’ll get at of that setting vs. stock (which I am not sure of).
Thanks in advance !
- How much negative camber were you able to dial in (assuming no hogging of holes)?
- What Caster setting did you use? I am unsure of the stock recommended; please indicate that also if you know it.
- What Toe setting did you use? I am unsure of the stock recommended; please indicate that also if you know it.
Thanks in advance !
