- 158
- 3
i just bought my second set of rims that I will use for track days. The boss is my weekend warrior car for show, track, autox or fun spirited driving. The new wider rims will be used for track days and I thought I would install the mm camber plates to take full advantage of the size tires I can use on the rims. Heres the question, if I use the stock rims for occasional weekend driving and put on the new rims and tires for track days, is it easy to adjust the camber when changing rims and tires? or is it fairly difficult and you can easily screw it up? Curious how these MM CC plates work and how easy and accurate it is adjusting them.
Thanks for your help
