- 130
- 0
Someone posted on SVT that Ford has replaced Motorcraft 5w-50 with Mobil 1 5w-50 in the Boss both right from the factory and as the dealer replacement.
Is this true?
Is this true?
zzyzx said:The current Mobil 1 5w50 lacks the WSS-M2C931-B spec required for maintaining the warranty.
Only Motorcraft 5w50 and Redline 5w50 adhere to this spec.
Not that that actually means anything in the real world, I'm sure Mobil 1 5w50 is on par or superior to Motorcraft 5w50.
I did my first oil change with Motorcraft and will be using Redline from here on out.
Dean#4AI said:Hmmm, are you sure about the Redline having that spec?
It does not state that it meets the spec.zzyzx said:Dean#4AI said:Hmmm, are you sure about the Redline having that spec?
http://www.redlineoil.com/product.aspx?pid=135&pcid=21
5 DOT 0 said:It does not state that it meets the spec.zzyzx said:Dean#4AI said:Hmmm, are you sure about the Redline having that spec?
"Popular for 5.4L Supercharged Ford applications like Shelby GT 500 and Ford GT (WSS-M2C931-B)"
That's my understanding. I wouldn't hesitate to use a non spec high quality motor oil like Redline or M1. I was just pointing out that Redline doesn't meet the spec. I get my oil changed at my dealer for less than it would cost me to do it so that's why I use the Motorcraft. A local shop to me stocks the M1 in 5w50 and that's what I'd use if I was changing it myself.gremlinsteve said:Doesnt this ford spec oil just mean its a low
Graphite formula? Im not seeing anything
Else different
