- 56
- 0
Has anyone changed the mufflers yet if so what kind.
BossJockey said:I remember someone installing GT500 mufflers on there Boss, but I can't find that post.
Have you used those ramps on the front? Was wondering if you need additional transition ramps due to the lower clearance.DigiCowboy said:It is not a difficult job. I did it using ramps, compared to the 2010 GT I did on jacks/jackstands. Much easier. For under $50 you can't beat those Blitz ramps. I had to get the 12,000 lb truck model to accomodate the Boss's rear tire width, but it made the job easy.
Did you get them online? Another option I'm thinking about would be to use those anti-slip adhesive backed strips used on stair treads or paint that does the same thing.DigiCowboy said:I was thinking I may have to drill a hole in the garage floor and use a drop pin to lock them in place to prevent slipping. They held good today, but the rubber piece underneath will probably wear off eventually.
cloud9 said:I have the Corsa Extremes and they sound great. Sounds very similar to the side pipes without discs. It does move most of the sound to the back of the car, although there is still some exhaust coming out the side. Best validation was when I finally got my wife to a track day after all these years and the thing she actaully commented about how much better my car sounded than the othersShe said it was easy to find me on the track and she said it sounded better than all those other cars you were passing lol.
As far as the weight someone on another forum weighed the stockers at 26.8 lbs so someone's scale is off. The Corsa Extremes weigh 12 lbs each.
No problem. It's part # 14317GotCurvz said:cloud9 said:I have the Corsa Extremes and they sound great. Sounds very similar to the side pipes without discs. It does move most of the sound to the back of the car, although there is still some exhaust coming out the side. Best validation was when I finally got my wife to a track day after all these years and the thing she actaully commented about how much better my car sounded than the othersShe said it was easy to find me on the track and she said it sounded better than all those other cars you were passing lol.
May I ask what the P/N was for the Corsa Extremes? I tried to get the Corsa Sports that I took off the 2011 GT I had and they did not seem to fit. The angles of the pipes were different. Thanks
IMO if you're good with the side pipes completely uncorked, you'd be happy with the Corsas in terms of volume.stumpy said:Cloud9,
Thanks for the reply and input. My Boss is almost entirely street driven, with an occasional trip to Road Atlanta or to the drag strip on Friday nights. In your opinion, would the Corsas be too loud for everyday use (if that is possible!).
