SOLD Mustang 05-14 Vorshlag Camber plates
100
109
Utah
Selling a brand new set of Vorshlag Camber plates, never mounted, still in original box and wrapping.
This was setup for 2.5" ID coilover springs. $375 plus shipping. Revised price to $300 plus shipping
  • Compatible with 2.5" ID,IMG_4290.JPG linear coilover springs.
  • Compatible with OEM diameter factory and aftermarket (lowering) springs.
  • Compatible with all strut types.
  • Installs with basic hand tools, no chassis modifications required.
  • Plates are designed specifically for the S197 Mustang chassis.
  • Caster & Camber are independently adjustable.
  • Camber is easily adjustable at the track with simple (metric) hand tools.
  • Caster is adjustable with three fixed positions: factory (front most), ~ +0.5 degree (middle), and ~ +1.0 degree (rea rmost)
  • The spherical bearing used in the Vorshlag camber plate is the largest used in any S197 Mustang camber plate. The result has much better durability and wear characteristics than the undersized bearings used in our competitors' plates.
  • Aluminum alloy main plate and steel alloy bearing holder construction - Tough as a tank!
  • All components plated for maximum corrosion resistance and long life.
109
Utah
The s197 camber plates are listed on the Vorshlag website for "From $439" and depending on your setup which you select on the website it can go from $439 to $539. These were $464 + $50 for the jig = $514 + shipping.
so bottom line is $400 + shipping. does that work for you?
Or, if you do not want the Vorshlag Jig for enlarging the strut hole opening, $390 shipped.
261
The website has a selection for strut style, can you elaborate?
100
109
Utah
For some reason, I do not get a message that someone has replied to a post I am following?
Yes, 14 choices. The Vorshalg camber plates I bought were setup for 2.5" ID springs, and Cortex Koni yellow shocks.
1,182
2,180
SoCal
Gonna have to take a chance and take these.....PM sent
When I ordered mine directly from Vorshlag, they didn’t show the KW V3 spring option on their site, but with an email they added it, and had the correct spring adapter on the shelf and ready to go. Should be able to get you fixed up and will still net out to a great deal.
