Need to buy a wax for a LSP on Blackfire wet diamond sealant / yellow blaze car
captdistraction
GrumpyRacer
1,941
1,670
Phoenix, Az
What wax would really set off my process and have a warm/wet look to it (yeah yeah) on my yellow blaze car.
(preferrably something budget friendly as its brutal in phoenix so will be going through whatever I buy fairly often).
My process is going to be this
Claybar
Zaino ZPC polish (on a medium pad)
Blackfire Gloss enhancing polish (on a lighter polishing pad)
Blackfire paint protection sealant (on an even lighter pad)
whatever wax is recommended as the last step
Using a griot's garage random orbital machine and by hand where necessary. The car has light swirls (very light) and a few marks here or there viewable under inspection with a bright point light source, I want to get it back into as good of shape as I can despite any sun-exposure wear and chipping from its tenure in Arizona.
I don't have YB, instead have SBY, but P21S has ended up being my topper giving the car a final wet look. I'm using the 100% carnuba, but experimented with their regular blend (cheaper) and it looked quite good too.
Capt
If not doing any correction, I do this process:
First, Menzerna PO85rd finish polish.
https://www.autoality.com/store/pc/viewPrd.asp?idproduct=321&idcategory=0
Second, Chemical Guys Black Light Hybrid Radiant Finish
https://www.autoality.com/store/pc/viewPrd.asp?idproduct=333&idcategory=46
Third, Chemical Guys Lava Wax
https://www.autoality.com/store/pc/viewPrd.asp?idproduct=841&idcategory=0
Finally, Chemical Guys V7 Hybrid Sealant/Quick Detailer
https://www.autoality.com/store/pc/viewPrd.asp?idproduct=331&idcategory=0
This is a fairly inexpensive way to get the yellow to look good. I have tried BFWD and it just didn't work for me. The CG items are synthetic so they are much more heat tolerant than a traditional carnauba wax and will last quite a while longer.
The comment about synthetics makes a good point. Is the OP prioritizing durability or appearance? What kind of appearance does the OP want?
For yellow I'd recommend chemical Guys e-zyme wax it's pretty pricey though. But dodo supernatural gives a great wet deep look that should pull the metallic flake out of your paint.
PeteInCT said:
The Zymol is good but the P21S actually has more carnuba in it and costs less.
Please don't take this the wrong way, but have you ever compared both on a SBY Boss? I have. The Concours brings out the color better, in my opinion. I really like the P21S, I just like the Zymol better.
PeteInCT
2,848
14
No offense taken. You did a real world test! I just get a little suspicious of the VERY high prices stuff. Some of it is worth it.
If you want to see my DODO and my chemical guys wax jobs:
https://trackmustangsonline.com/vintage-boss-302-and-351-forum/boss-all-waxed-up/
They are taken with my iphone, but you can gauge enough from them.
Ha, I tried both and like the P21S better. Goes to show you, got to try them yourself to decide for yourself.
captdistraction said:
So I'm trying the p21s.
I spent under $200 and got the buffer, wax, pads, sonax wheel cleaner, leather cleaner, some clay, leather freshener, and a few other items I'm forgetting. So at a minimum budget, I think I did damn well
Be gentle with the buffer, particularly near any stripes.
I was VERY skeptical of Zymol as well, but when I finally broke down and applied it, I couldn't have been more impressed. I have a jar of Swissvax Concours at home I need to try too. I used Zymol Carbon on my black GT with great results too and it is a lot cheaper. In the end, it's really personal preference. The only thing that isn't opinion based is heat resistance and longevity. That's where the synthetics really shine ;)
captdistraction
GrumpyRacer
1,941
1,670
Phoenix, Az
Will do, I'll be sure to tape any striped surfaces. Unfortunately they had to come off to get some paint work done (Tiger 302S hood, B302 front Grille off AzGT's car), but I'll try to do the correction before replacing them. The new paint work should be in amazing shape, and once the painter gives the the all clear to seal/wax it, I think that's all it will need. The rest of the car will get the polishing and clay treatment.
