I can tell you from first hand experience the first rep is full of it. Replacing the uber cheap stock speakers will make a huge difference.seca954 said:I contacted JL audio about replacement speakers for the Boss. They told me that replacing only the speakers might sound worse becuase the radio was designed to equalize the cheap speakers that Ford installed. Then I talked to another guy from JL and he disagreed and told me the speakers would be a great improvement. Please confirm if you are happy with the results of a speaker only swap.
jneuman said:Insert images didn't work .... sorry folks.
Just got the car back from Automotive Concepts https://www.facebook.com/automotiveconceptsmn
The sound system is out of this world - it is loud, crisp, and the JL sub is tight - hits hard, and is very responsive. The midrange is crystal clear and louder than I expected. Midrange were factory replacement, the JL stealth takes up very little room, and the amp & audio processor are installed in the spare wheel cavity.
When I drove it away I noticed a raspy static like sound coming from the driver side door when the volume was all the way down. Took it back to AC and the audio technician was able to pinpoint the sound - it was the metal 'Powered by Ford' plate in the bottom of the door jam. He put a small piece of foam under it and the problem was solved. This must have come from more vibration in the car since the exhaust limiter plates were removed.
https://sphotos-a.xx.fbcdn.net/hphotos-ash3/774333_10200396194178148_1628049962_o.jpg/img]
[img]https://sphotos-a.xx.fbcdn.net/hphotos-prn1/798278_10200396194098146_1893162948_o.jpg
racered302 said:How do you like the c3 ? I was going to go with them but my friend decided I needed the c5 being I have 150 watt to them each. The funny thing is I hardly even use the radio.
I've got 125w to each but when you do your amp you need to adjust it so you don't blow it. Set the Head unit 3/4 volume, set the amp input to the lowest level, adjust the amp until it starts to distort then back it off until it's clean. That gives enough margin of error on the head unit so you don't blow the speakers I'm not sure how loud you like it but mine goes plenty loud before I hit 125w.Also the C3 sound good in my car but I can't say whether or not the C5 sound better.
cajundao said:Did you run new speaker wires through the boots or kept the stock wires?
racered302 said:That short of a run I don't think you want to go through the trouble of modifying the connector to get a piece of monster cable in the door. I have the JL audio C3 installed in mine, ran the heavy speaker cable from the amp to the crossovers in the center console then out to the front speakers using the factory wiring, I like to crank it up every now and then and have been complimented on the sound many times.
cajundao said:So you installed the tweeters on the A pillars?
racered302 said:Yup, the imaging sounds fantastic. Close your eye's and you can't tell where the sound is coming from. I installed them at about the same place that 2015 Mustangs have them.
racered302 said:There is no way to avoid the pillar mount if you want good imaging unless you wear headphones, if there is let me know and I'll go in that direction. These pics suck, I mean the light reflecting off the edges aren't that noticeable and I stand by that. It's always a PTA to post pics here because of the hosting services needed, but I understand the lack of server space, so here goes. Not working, getting pissed, cut and paste is much easier. Hopefully by the AM.
