How did they fit the rim? I am using the same rims as you have?
Sent from my DROID RAZR HD using Tapatalk 2
cloud9 said:Tires last more than a weekend ???
I'm surprised you didn't notice more of a difference. I now have four track days on my Hankook RS3's and there's a huge difference with them compared to the stock Pirelli's. I'd be surprised if the Hankook's are better than the NT01's plus the Nitto's are wider.
Hermes said:Ran 3 half hour sessions for 3 days at Watkins Glen this weekend on the NT-01. This was my 9-11th track day so I'm kind of new to this. My impression was that these tires worked well mid corner and I could definitely carry more speed through the corners. Grip was better, but it wasn't a night and day difference from the stock P Zeros I had been running. I did notice that the car felt unsettled in transition [most noticeably turn 2 - 3 in the climbing esses for people familiar with the Glen]. This was something I had not experience with the Pirelli's [may not have been carrying as much speed, but I doubt it]. I increased rear shock setting from 4 to 5 and this helped a bit. Also noticed tire roll indicator showed I had too much air pressure so I eventually took out a total of 1.5 psi. I ended up running these at 36 rear and 37 front [hot] which seemed to work well. I have no camber plates.
Pushing the tires past their limit a couple of times gave gradual breakaway, so nothing to worry about with an abrupt breakaway. I measured tread depth before and after my 3 day 4.5 hour total track time event and wore down roughly 0.012" averaged between the tires. There was no indication of any abnormal wear [including outside edge of front tires]. I will be putting camber plates on before my next event, I just like to make one change at a time so that I can tell what effects each change has on the cars dynamics.
neema said:
Domestic Product said:Nice GT and great brakes, looking good! What are you running suspension wise? car sits nice. You do however need to work on your numbers .
I used to run NTO1s on my M-3 when I had that. Great tire can drive on the street a little bit and does real well at the track. Price is good. Have not used the NT555R11s , they look good and size wise they look made for the Mustang. I was told that Toyo makes Nitto and they share the RA1 and 888 technology in the Nitto brand showing up first in the NTO1s and then the NT555R11s. All four great tires. When I add 18x10 wheels next year one of these will be on them.
Nto1s
305/35-18, 12.32" wide , 26.42" tall, 1,819 load.
275/40-18 10.91" wide , 26.65" tall, 1,709 load.
Nt555r11s
305/35-18 12.48"wide , 26.30" tall , 1,819 load.
285/35-18 11.22"wide , 25.92" tall , 1,609 load.
NFSBOSS said:neema thanks for posting. Did you have to use spacers and what size wheels are those?
BTW nice grille.
Hermes said:Tires just came in yesterday and I'm going to have them on the track Friday! The outside tread blocks are HUGE on these tire, which makes them almost like a slick. Did a few weights before getting them mounted.
Nitto 275/35-18 27.4 lb
Nitto 305/35-18 31.8 lb
Forgestar F14 18X10 21.0 lb
I'll let people know how they worked for me after my 3 day event at Watkins Glen.
ArizonaGT said:Nice Vette, hermes. I'll bet that turns some heads!
Post some pics of your car with the forgestar and the NT01
I am curious to see how these fit on same size frt & rear wheels.
Thx
Hermes
1965 roadster?
I didn't know where to start with pressures, so I just ran 33-34 cold/38-40 hot. they felt okay, but some suggest ~38 is a good hot temperature to run. I'll try a few less psi next time.
Hermes said:I ended up running these tires for 6 days [3 at Watkins Glen and 3 at VIR] I kept notes on starting tire pressure and end of session pressures. I marked the sidewalls to see how far they were rolling over compared to the marks Nitto puts on the tire to indicate proper roll over. I found that I needed 37 psi rear and 35 psi front hot to give good roll over indications. I consitantly measured temperature as soon as I pulled into the paddock after a half a cool down lap. Ambient temps at VIR were high 80's to mid 90's and my starting pressures were about 30 psi. Watkins Glen was similar, but my starting pressures were 28-29 psi.
I plan to get a pyrometer and start checking tire temps next season, but for now the sidewall indicators were all I had to help me get the pressures close.
By the way tire wear has been excellent [maybe I'm not pushing them hard enough]. I measured an average depth of 3 of the dimples on each tire new, after 3 day at WG and after 3 days at VIR and saw about 0.012" of wear after WG and an additional 0.015" after VIR. The remaining depth is about 0.155 front and 0.165 rear. The rear dimples were deeper when new. Wear front to rear seams to be consistant, but I am wearing the outsides of my fronts faster than the insides. Hope to get camber plates for next year to help balance the wear as well as work with the temps to maximize grip.
