Thanks Steve, I'll be sure to add the washers.
I've now figured out how to increase clearance between the swaybar and the stock oil cooler hoses. Release both hose clips on the bottom radiator hose and rotate it clockwise (looking from below). A small rotation (less than 10 degrees) more than doubled the clearance.
Mine was set too close and I'm going to have to change out the RH cooler hose before it fails......
