I realize a lot of you guys don't run these, but I was hoping maybe someone could fill in some gaps for me. I'm replacing my shocks and struts and I got some new old stock BOSS OEM strut mounts to go along with the install (I think I have mounts from the old V6 on there currently). When I received the 2 strut mounts, one of them came in 2 halves with the still sealed plastic bearing housing visible in the middle of one half. The plastic tabs that hold the plastic bearing housing to the mount are broken. I wanted to compare it to the other one so I gently pulled the other one apart and on this one, the bearing housing split in two revealing the bearings inside. I did it gently and I don't think any bearings got out, but to be sure I counted 47 bearings in total in a yellow grease. I then opened the broken one and compared and it also had 47 bearings inside. The seller has additional NOS BOSS OEM strut mounts and they are providing me with a replacement for the one with the broken tabs -- although I think it probably doesn't matter since they'll be held together by bolts anyway...
So I reassembled the good one, making sure to keep as much grease inside the track as I could. Afterwards I noticed that a slight pressure to one side or the other can misalign the bearing housing and you can feel it move. When you hold it together and spin it, it feels OK. Did I reassemble it properly? Do I need to apply a lot of force to get these things to sit together properly? Or is this just the way they are until the bolts hold everything in place? Basically my concern is did I ruin it by opening it?
It seems like it is common for a lot of people doing strut replacements to have these things pop open. I would imagine that I can just put them back together and everything would be fine as long as all of the bearings are in there and everything is properly greased... Should I add more grease while I'm here? I would guess that it's this stuff:
I know there are better options for strut mounts but for now my plan is to restore this car to OEMish condition before I start in on the mods. Want to see how it handles in top form first and then I'll start changing stuff. My car is basically a salvage restoration project at the moment. Getting pretty close to like new condition.
