Oem engine oil
237
Hey guys ,
I forgot to ask whats the oem engine oil mileage ??
I think the oil i'm using is mastercraft. 5w50 or 20w50 i forgot
And here at summer it goes in the 50s degree celcius but at winter weather gets to 0 and on daytime its in the 20s
eng90 said:
Hey guys ,
The OEM oil is Motorcraft 5w50 full synthetic.
You're gonna need the full synthetic for the temperature resistance at high RPM and the 5w50 to maintain proper viscosity for VCT functionality as the oil degrades with temperatures as well.
Been running Castrol Syntec 5w50 for quite some time now with no issues at 60% the cost of the Motorcraft stuff. I used the Motorcraft stuff until the price spiked in 2012.
2,203
1,067
Bay Area
It depends on your driving. Below is from the owners manual. http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/13musom3e.pdf
Change it after every track use or
When to expect the OIL CHANGE REQUIRED message
Miles (km) Vehicle use and examples
7500-10000
(12000-16000)
Normal
– Normal commuting with highway driving
– No, or moderate, load or towing
– Flat to moderately hilly roads
– No extended idling
5000-7499
(8000-11999)
Severe
– Moderate to heavy load or towing
– Mountainous or off-road conditions
– Extended idling
– Extended hot or cold operation
3000-4999
(4000-7999)
Extreme
– Maximum load or towing
– Extreme hot or cold operation
