OS Giken vs Torsen
Grant thanks for the depth on the Torsen. I mainly autocross with a handful of trackdays a year so a good compromise between the two is what I’m shooting for. Sounds like the Boss T2R might fit the description. I know you run a Torsen of some flavor in your car. Which bias is it? Also how much power is Axstang putting down?
There’s a local guy here that specializes in OSG setup so I was gonna have him go through mine if I went that route. I think I have ruled it out honestly though. As Speedboosted said the couple tenths faster it would be aren’t really worth the extra $1000 .
I don’t do any drag so the worst shockload the diff will get is R Comp launches at autocross. So it’s Torsen 2.7/4.0 vs. TrueTrac now...
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
Do these Torsen differentials allow "regular 2008 GT axles" to be used directly? I think I'm in for a ring & pinion as it is, and I'd consider stepping up to a Torsen while I'm at it . . . as long as doing so doesn't require extra modification to work.
Norm
@Norm Peterson I'm not sure if there is any fundamental difference in the 8.8 rear throughout the life of the S197--to my knowledge they are all 31-spline axle shafts with the same lengths etc. So it should fit any V8 S197 rear end.
Norm Peterson
939
712
Thanks, guys.
What I'm not seeing in the pictures is a clear indication of where the U-washers (aka C-clips?) would go. I've done a couple of differential changes on a different car and had to replace axle seals on this one, so I've at least seen the inside of an axle.
Norm
On the FB page Billy Johnson gave a strong recommendation for the Eaton True Trac. I know nothing about the different diffs but wanted to pass this along.
Thanks.
On to deciding which one to get. I'm thinking that having only a normally-aspirated 4.6L (and no more autocrossing) might mean less need for a big TBR.
Norm
I think the choice, then, would come down to tires you use. I think the higher bias makes more sense toward more grip with larger and/or stickier tires. The N/A FR500S uses the 4.0 bias unit originally with 245 R1 slicks IIRC. It *should* be faster as you approach tire lifting conditions. I don't think you'd go wrong with either.
Norm,
I pulled a GT500 rear end from a salvage yard and rebuilt it with a Torsen T2R (4.0 bias) and installed 3.73 gears. The stock axles worked on mine.
http://stangsunited.com/showthread.php?4777-Torsen-T2R-Recommendations
Torsen recommended the 2.7 to this guy that had a GT500 based on his power level. This was back in 2011 though so I think that was before the latest version of the T2R. Funny because in the email the Torsen rep recommends that he not use the T2R if he is on slicks despite the fact that the T2R was developed for a race car on slicks (Fr500). I think all things considered the 2.7 Torsen is gonna be the best for my car. It has a slightly higher TBR than the TrueTrac and is more reliable than the 4.0 unit for a powerful car.
