I saw an article on hood and fender side vents on the forum here discussing the pros and cons for each. The 59 T-bird is at least in the Ford family !! I have had the car since 1967 and it has large and very well cut in front fender vents going directly into the engine compartment. You can look from the engine compartment , thru the vents, and onto the pavement. There is also a small reversed hood vent on the passengers side about midway back on the hood. None on the drivers side. The workmanship is show car quality. No one knows anything about the where or why of the car. It looks like a show car but has double shocks per wheel, traction rods, pan hard rod, open wheel wells on the back side fully exposing the tires, 3 speed overdrive and 430 Lincoln engine. No other power options except radio and heater. Top speed I have driven it is 160 mph and was staying on the ground. All body work seems to be lead. Question: do the vents really help or just for looks ??
Thanks for any responses and comments on what this car was built for. I got it in Omaha in late 1966 with 30,000 miles mark
