Output Shaft Flange Nut Location for TSB 19- 2135?
39
28
Atlanta
After my latest track day I noticed my car experiencing surging issues and cruise control not working as similar to what's described in TSB 19- 2135. (https://static.nhtsa.gov/odi/tsbs/2019/MC-10162060-0001.pdf)
Can someone tell me if this is the output shaft flange nut that would need to be replaced or tightened? I'd take it to the dealer but they are slammed for the next 2-3 weeks and if it's something simple I can fix myself I'd rather give it a try.
7
7
Mooresville
I had the same issue on my 2019 GT350 The dealer had to order special parts to fix the problem it took about a week for them to arrive. Makes me it's not as simple as tightening the nut.
It is that simple, but the TSB requires replacing not only the flange nut, but also the other bolts/nuts for the drive shaft as well.1654654482364.png
65
104
Nova Scotia
It is that simple, but the TSB requires replacing not only the flange nut, but also the other bolts/nuts for the drive shaft as well.View attachment 76425
Ford regularly requires bolts be replaced mostly because they don’t trust the techs to use the correct thread locker on the bolts when they reinstall them. If there is no stretching out other deformation, the bolts will be fine.
I also had the same issue. I had a post about two years ago about the TSB and getting it taken care of. Question, can you please explain where under the car the picture is taken?? If it happens to me again, I would like to be able to locate the nut. Thanks
39
28
Atlanta
Right underneath the shifter. Nut is on the back of the transmission where the driveshaft connects.
