cloud9 said:I just mounted up a set of sticker Contis and they say spring rate xx 30 psi @ 800lbs which looks to mean target a 3200 lb car so I was thinking of continuing to target 32-34 hot in our 3600ish lb cars.
YellowBoss said:Wow, you guys are running the Conti's lowI have been going with 39 in the front and 37-38 in the rear. I get good wear with that pressure but may try a little lower next time out and see how they handle. When I first tried them I corded two sets quickly at 34-35.
blacksheep-1 said:that's hot...correct?
What do you recommend for HOT pressures on our heavier 3600 lb cars?blacksheep-1 said:Check my last post, I did a ninja edit there, but that sounds about right.
cloud9 said:What do you recommend for HOT pressures on our heavier 3600 lb cars?
I only gain 1lb more in the fronts hot than rears. Been starting 26 front 27 rear and landing about 33-34 hot. The stickers on my brand new Contis show spring rate at 30 psi hot. I typically run DOT tires like Nittos or R6s at 40-41 hot but was always told to run slicks vonsiderably lower. In fact the Corvette guys run them around 28 hot but they're lighter at around 3100 lbs. I guess I could give higher pressures a shot and see what happens.blacksheep-1 said:Look at my last post 29-31 in front 25-27 in the rear, opposite of what yellow boss is running. Stay under 42 hot if you can, def 45.
This becomes a whole science that begins with cold pressures at a specific ambient temp, you need to keep specific notes on all of those parameters. Honestly, I'm not at much liberty here, I can push you in the right direction but then you're on your own..sorry.
