PP2 wheel offset request
Offset update: My 2018 PP1 has 19x9x45 front and 19x9.5x52.5 rear.
Stigs bald brother posted images of 2015-2016 PP wheels (earlier in this thread) as 19x10.5x30 front and 19x11x62 rear.
Are the larger wheels possibly the same as PP2? Please reply if you can confirm.
Also: Last night I test fitted Konig Ultraform 18x10.5x25mmx lightweights (21 Lbs) on my 2018 PP1. They clear the calipers by appx. .060". At about $200 each, they're a heck of a deal.
I believe Stig posted specs for the stock GT350 wheels.
4,018
1,964
I will give official offset numbers in a few days when car arrives. My educated guess is the offsets are the same as base GT350 wheels. If this is true for the rear (should be) then my plan to use rear 19x11 with 25 mm spacers up front won't work because the resulting 37mm effective offset will still be too far inboard. A 35 mm spacer would be more in line but that is too much spacer even for me.
Thanks! I/we look forward to your report. Please confirm: Did you buy a PP1 or PP2?
492
387
DFW, TX
The pictures I've seen of the rear PP2 wheels looks like they stick out about 3mm more than the base GT350 wheel, more like the Apex 19x11 offset.
