- Thread starter
- #41
ArizonaBOSS said:
ArizonaBOSS said:
It did not come with the AIM setup, its a ProSport M22xP1.5302 Hi Pro said:J3st3r:
I like the looks of that sandwich plate for the sensors, any manufacturing ID on the part? (I'm assuming it came with your AIM kit.)
Need to locate an oil temp sensor.
Thanks,
2HP
j3st3r said:It did not come with the AIM setup, its a ProSport M22xP1.5
Mad302s said:Curious why you chose 3.31 Gears if you have 3.73's needing longer gears? I only ask since i have 3.31 and wouldn't mind going to 3.73's
bpracer said:I'm curious also, I know Vorshlag is proponent of this, but I haven't heard the particular reason. I think they have said something about keeping the engine in the middle of the torque band....
modernbeat said:Since I've been summoned ;D
Factor #1
What we found was that the S197 GT engine had a significant torque bump in the middle, but horsepower tapered off at the top. This is relative to the BOSS302 engine, which actually had LESS power than our GT in the midrange, but at the very top it kept going while the GT topped out.
Factor #2
Instructing students we found that when they kept the revs in the top of the power band that shifting was harder, balance was harder for them, and that the car was just more frantic.
Factor #3
Heat. And lots of it. On any car with the short 3.73 gears and a Boss intake we found drivers kept the revs at the top of the rev range so they had adequate power. Extra revs to get the power create a lot of extra heat. More than the BOSS cooler could fix. More than an auxiliary cooler can fix in some cases.
Factor #4
The good tires were short! Like really short. The popular 315/30-18 tire, which was THE tire at the time, is very short for the S197. FWIW, for competition purposes it is still THE tire you want to use if you want to win. But, the couple tires in that size are a hassle, so I only recommend it these days for championship efforts.
What does it mean?
In an effort to make the car easier to drive, produce less heat, work with the shorter tire AND have more usable power, I recommended the 3.31 for cars with the GT engine and 3.55 for cars with the BOSS engine (intake and cams). For those that made the change, they saw the benefits including lower lap times.
Today, the S550 GT makes all the horsepower of the BOSS and all the torque of the S197 GT. And, more 305/30-19 tires have come out which is GREAT for track days and casual competition. The heat management has gotten a little better. And it's harder to overdrive the suspension, though the transmission is still not what it could be.
So my recommendation today? It's a little more complicated. The S550 should most likely use the 3.55 gear. It seems to work best. For the S197 I'd still stick with my earlier recommendations. The 3.31 for the GT and the 3.55 for the BOSS. If you are going to run a 19" tire, it's a factor I'd consider, but unless there were some other changes, like a lot of power added, or huge weight reduction, I'd stick to my earlier recommendations.
