Proper Wheel Spacer size
470
443
MD
Hello all,
Putting together my shopping list for track season next year and was wondering about spacers and wheels.
Is it possible to run 28mm spacers up front with +52 wheel (apex ec-7) on the 1" ARP studs?
I will have a 3mm spacer at the rear so I'm just thinking to make proportional changes to the track width of front and rear, I would get the 28mm instead of the 25mm.
1,249
1,243
In the V6L
Hello all,
How wide are the rims? 11"?
I have an excel spreadsheet that allows me to check if a specific stud will work with a specific spacer. The 28 mm spacer is thicker than I'd use on a race track with the ARP 1" stud because it will only have a bit over 18mm of thread engagement in the lug nut. Personally, I won't run less than 20mm for the track. A 25 mm spacer or even a 26 mm meets my criteria - of course, it's entirely up to you to decide what you think is ok for your use.
The one thing I can't tell you is if an 11" rim with a net ET 24 (52-28) offset will work on a GT. Ok on a GT350 but I believe that the GT350 fenders are a bit wider.
470
443
MD
Thanks for the response.
its the 19x11 +52 by Apex. I know a +24 will work with a GT because I had MRR M600 in a 19x11+24 earlier this year that I used for a few events.
So I guess if I go with 26mm then the 2mm won't make a difference in the handling. OP mustang has new Studs that I could use but I think Im just overthinking it. Thanks again for your response
https://www.opmustang.com/store/p386/14MM_GT4_Mustang_Type_Racing_Wheel_Studs.html#/
