Has anyone installed a set of these yet.....wondering if they would mess with the warranty........think it would be fun to be able to change the way it sounds with a remote.
raypfatboy said:Has anyone installed a set of these yet.....wondering if they would mess with the warranty........think it would be fun to be able to change the way it sounds with a remote.
depends on which kit you get. one is just a switch open or closed one comes with a remote to open it as little or as much as you wantJB said:I have a question about the kit. Is it basically that they have two positions, open and closed? Or can you adjust the amount of sound with these across the range?
Justin said:depends on which kit you get. one is just a switch open or closed one comes with a remote to open it as little or as much as you want
681 LS said:Has anyone tried to machine a 3/4 hole in the plate so it could not be closed completely?
I stand correctedjim woodruff said:No, both kits you can open or close part way.One is just the remote control on a key fob.
