Not sure how many of you guys are using Dashware to create overlays on video. I am still using the trial version since I want to vett it out fully before purchase. Two questions for those that have more experience with it than I do with it:
1) I can't seem to get it to handle the GPS positioning data that draws the track map and shows your position on the course. The red dot just sits it the bottom left corner. I am sure that I have that gauge widget set correctly yo X & Y GPS coordinates (set in Degrees). All the other gauges work (speed, lap, G's, etc.).
2) I have a I7 quad core Windows 7 PC laptop to run the software but I'd rather do it on my IMac since it has better video editing capabilities, bigger monitor, etc, etc. I am trying to install Dashware while running VMware within a Windows Vista virtual machine (wish I had Windows 7 disks but I do not). Initially it had issues with my version of .NET however that has been resolved with the latest updates. Now, when I try to install it it just fails after starting the install process (after the package in unzipped): Here's what I get:
The install dialog box reports the following upon failure:
Component Windows Installer 4.5 has failed to install with the following error message:
"Incorrect function. "
The following components failed to install:
- Windows Installer 4.5
See the setup log file located at 'C:\Users\PETERD~1\AppData\Local\Temp\VSD2692.tmp\install.log' for more information.
The tail end of the install log contains only the following:
'Windows Installer 4.5' RunCheck result: Install Needed
Verifying file integrity of C:\Users\PETERD~1\AppData\Local\Temp\VSD2692.tmp\WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU
WinVerifyTrust returned 0
File trusted
Installing using command 'C:\Users\PETERD~1\AppData\Local\Temp\VSD2692.tmp\WindowsInstaller4_5\Windows6.0-KB958655-v2-x86.MSU' and parameters '/quiet /norestart'
Process exited with code 1
Status of package 'Windows Installer 4.5' after install is 'InstallFailed'
File trusted
