- 5
- 0
A quick tip - our cars are equipped with a "clear flood mode". This means if you crank the car over with the gas pedal pressed down all the way to the floor, the computer will prevent the car from starting by disabling the fuel injectors.
This is helpful after an oil change if you want the engine to build up oil pressure before allowing the engine to start.
