We'll find out soon enough.
Looking forward to your results. I'm having my MM cc plates installed while I'm in Utah since they're the only option on the table right now and I have an event in three weeks. Will Vorshlag have their plates ready when they install them or are you just going to reuse the factory strut mounts?bpracer said:I just ordered a set for my Track Pack. I'll see if Vorshlag will put them on their spring rate machine to see what is really going on here. There was no definitive answer as to which cars had which spring rates from Ford. I'm going to guess the Track Pack and R are the same except for ride height. Either way, I should know in a couple weeks when my car arrives.
I think Vorshlag has their plates finished or at least they are in production now. The owner had a Facebook post with a run of freshly CNC'd S550 plates for the stock spring perch (he was joking that S550 guys had been pestering them...). I live in the same town as their shop.cloud9 said:Looking forward to your results. I'm having my MM cc plates installed while I'm in Utah since they're the only option on the table right now and I have an event in three weeks. Will Vorshlag have their plates ready when they install them or are you just going to reuse the factory strut mounts?
The reason I'm curious is I don't think the MM plates are going to yield enough camber and I may end up going with Vorshlag or Cortex once they're available, assuming they yield more camber. If I end up switching plates I would want to install the R springs at the same time.
VoodooBOSS said:I'm pretty sure the R front springs are shorter and stiffer. To me the question is if the rears are different.
I received an update on Friday that the FP lowering springs continue to progress but it's still going to be Summer, maybe late Summer, before they are available. They are testing them on track so they should be an improvement over stock on track.
Then just stick with the stock springs for now. The car is quite capable as delivered. Add come CC plates and sticky tires and you'll be set.bpracer said:If you look up the parts online, there are far more spring part numbers than what one would expect. The limited data Ford published just doesn't line up with the various part numbers in the system. I'm not looking for a punishing ride. The tracks around here are not exactly smooth and that goes double for the concrete streets.
VoodooBOSS said:Thanks. Did they test the non R GT350 springs?
