Radiator & Oil Cooler Fencing
316
264
Dave_W
1,003
1,311
I looked into this a while back. There are basically 2 categories of backer rod - ones for ambient temperature sealants (e.g., latex caulk) and able to stand up to 150-200F, and ones specifically made for "hot pour" sealants (e.g., tar) that can hold up to around 400F. You want a "hot pour" backer rod for sealing around the radiator. Not sure if it's carried in the big box stores, maybe you can ask at the pro/contractor desk. Or check your local masonry supply store if you have one.
316
264
Well I learned something new today, Thanks!
Did you use this stuff on your car? How did It work out?
I think you’d be better off using something like the insulation for hot water piping. Could be used to cover edges and usually can be found with an adhesive that could be used for attachment. But the high temp backer rod should work fine.
Dave_W
1,003
1,311
Haven't needed to do it to my car, just did a bit of research. I autocross the Boss, so cooling isn't an issue with the short runs. I've tracked my "backup" cars - Escort GT, Fiesta ST, Miatas - that I don't care as much about messing up. Learned that back in the 90's when I saw a guy with a brand-new car roll it; fortunately he had a rollbar in it but it caved in the A-pillar and wiped off both front fenders.
6,553
8,204
I used sticky back EPDM foam strip. So far so good.
I use this stuff all the time in industrial applications.
316
264
Perfect! Just ordered. Thanks!
9
6
46038
And the stickum doesn't loosen when applied directly to the hot cooler?
6,553
8,204
It’s sandwiched between the cooler and radiator so it can’t go anywhere. It’s industrial grade material so it’s very high quality.
I had the radiator out over the winter and it’s still firmly attached.
This is the second racing season on this setup and it’s hanging in nicely.
6
46038
So far so good.
I had some of this gasket lying around, so I heated a soldering iron to 350F and then held the gasket and its stickum against the iron. No smoke, and no melting!
I had to see for myself.
