I got around to the first front brake job on the fronts.I located a set of Raybestos EHT 1050 pads.The rotors looked like new-very smooth across with absolute no gouges or scrapes.They are true with no warp.After about 100 miles of gentile break in,I decided to try a high speed run and a quick stop.Stomping on the brake pedal,it felt almost like a ABS feel,and the brakes sounded terrible.Like my old 2002 GMC- hard brake-ABS lock up sound.Not a grinding sound,but almost like they are not releasing,not sure.Then i tried another stop,but not that hard,and same thing.I just went over the front end,and also pulled out the pads .They look awsome so they went back in.It sounds like the right front may be the area,but it's hard to tell.Normal braking is fine.I noticed these pads are a hybrid ceramic and semi-metalic compound.I checked all strut and swaybar bolts.I did recal reading about a recall of front lower control arms last year.Could it be these pads? Or possible a defective controll arm?I'm kinda stumped,after I have gone through it twice now,and the rotors and pads look great.
