The large steel dampers that are mounted to the rear lower control bracket. Has anyone removed these and what was the noise effect ?
jim woodruff said:The large steel dampers that are mounted to the rear lower control bracket. Has anyone removed these and what was the noise effect ?
I think they weigh around 5-7 lbs each? Unfortunately it's low on the rear of the car......the opposite end of where we most need weight reduction.TMSBOSS said:I removed mine. A slight gear like noise has shown up since. Usually shows up around highway speeds with load.
