The rear tires have very little vertical loading under braking, so they don't contribute much or need much torque to reach the limit of grip under braking. A big wing helps a lot but if you don't have one, your rear pad is way too aggressive and putting a street pad on the rear will improve your braking performance.For what it’s worth, I run a much more aggressive pad in the rear - G-Loc R12 which is equivalent to Carbotech XP12 and I had not had any issue like that.
