Rear camber
This question has probably been asked but, I couldn't find it.
What is the Max negative camber you can get out of the stock gt350 back without aftermarket camber mount adjustment kits?
Has anyone tried the Steeda Camber Mount Adjustment Kit Rear 2015-2019?
I just installed camber plates this weekend to the front and taking it for alignment tomorrow.
Not sure what the max is but you should be able to get more than what the supplement suggests.
HardYakka
Avalanche Gray '17
You didn't explicitly ask if the kit increase the camber range, but...
My understanding is that the Steeda kit doesnt increase camber adjustment, but simply makes the process much easier to adjust.
https://www.cjponyparts.com/steeda-camber-mount-adjustment-kit-rear-2015-2019/p/CCP49/
From the site: Please Note: This Kit will NOT provide additional camber adjustment but will help utilize the full 2.0 degrees of adjustment from the factory allowing you to easily dial it in with a turn of the wrench.
Just in case you were wondering!
I'm also in the camber tuning phase of my setup, just bought the Maximum Motorsports plates. Which ones did you go with?
