cloud9
Gary
Ok track guys I need some help diagnosing an issue. This past weekend at the track I started experiencing an issue with what I believed to be the rear end. I ran my first session at MPH in cool temps (47F) and everything went great. There was a lot of traffic and I only got one clean lap and it was 0.2 seconds faster than my best lap over two days at the Mustang Roundup a month ago. In the second session I started getting an issue with what I thought was the rear end in Turn 12 which is a sharp left-hander that comes right after a sharp right hander. The right rear "felt" "sounded" like a growl/vibration and I seemed to be getting excessive rear tire slippage when I laid the power down at apex. The noise/feel issue was only on left hand turns and mostly just in that turn. However, I felt that I was getting excessive wheel slippage powering out of most turns. My lap times climbed 2-3 seconds, but part of it was probably the fact that I was backing off a bit being concerned about the rear end coming apart. We put the car on jack stands and one of the track mechanics diagnosed it as outer wheel bearings on the rear axle. We took the rear end apart, inspected the gears and axles and there was no apparent wear or damage. There were NO metal filings in the fluid or at the bottom of the diff. We also replaced the wheel bearings to eliminate that issue since there seemed to be excessive play according to the mechanic. The bottom line, the rear end, Torsen and axles all appear to be fine so shouldn't be an issue.
I went back out the following day and experienced similar issues, albeit maybe not as noticable. My lap times were more like 1.5 seconds slower, but so were a couple other guys so could have been conditions. When I got home I looked at my tires from Friday and noticed some very weird wear patterns on the rears. There's a 3" section that's worn more than the rest of the tire but doesn't go the full circumference. The rears also seemed to wear way faster than normal. I don't wear out the rears very fast running R6s or Conti slicks, but I go through fronts due to cording the outer edges. Someone suggested possibly a brake issue and I'll have them inspect for that.
Here's the kicker. When I got home Saturday night and went to unload the car off the trailer, it wouldn't start! There was plenty of voltage and the gauges would sweep and fuel rail charged, but wouldn't turn over at all. We even put a jump pack on it and nothing. I've had a "check charging system" error only on track. The dealer can't diagnose it because it never does it on the street and doesn't leave any codes. I'm hoping whatever is causing it not to start is connected to this issue so we can kill two birds with one stone. I should have this diagnosed today.
Any ideas on what potentially could be going on with the rear end would be appreciated. These wear patterns have me puzzled. I did email the pics to Hoosier to see if they've seen it before. Best case scenario would be the tires were just bad and I don't have an issue with the car.
