Getting a stage 2 MT-82 rebuild from Texas Drivetrain Performance for Christmas. Wanted to ask you guys what you think -- what should I have done while we're there?
OK 1st, why did I not do a Tremec? I thought about it. I don't think the 2.97 1st gear would bother me that much, and I am definitely of the camp that believes that the MT-82 1st gear isn't very useful for much other than drag racing. From what I understand, with the Bowler harness everything can work pretty well (although I do wonder about Bluetooth security issues). But I've also heard of people having issues with things like cruise control and it sounds like I'd be married to a custom tune as well. I do plan on getting an AED tune for the car eventually. But if I do a mod that REQUIRES a tune I would want it to be something that increases power.. like E85 injectors or cams or something. I like being able to run the stock tune if I want. I want EVERYTHING to work properly, cleanly, and with a minimal amount of NVH (more than stock OK, but want to keep to a minimum) and for these reasons I chose to stick with the MT-82.
The Texas Drivetrain stage 2 is similar to a Calimer stage 3 I think, except they use AMP gears that are of the same ratio as stock. And since they aren't too far from me, if anything goes wrong I can actually go back to them to work it out as opposed to pulling the transmission and hoping that Calimer will stand behind their work -- which sounds like a gamble from what I've been seeing.
So to the question: While I'm getting the tranny rebuilt, what else should I have done? I see a lot of guys on here who say that if the transmission is out, do the clutch, flywheel and throwout bearing while you're there. Initially I'd planned on doing this but TX Drivetrain said there's no need and that if the clutch was worn that they'd let me know so we can replace it. Sounds reasonable... and from what I can tell the clutch is fine. Then I was thinking I could at least do a steel clutch line (I was thinking the FRPP one). So I went to look at TMO opinions on that and found this thread:
It seems like you guys don't think it is necessary unless you have long tube headers? Which I will not be doing. I don't know the difference on this one, I only know that many say that the clutch, "feels" better and I don't mind springing for it if it actually improves performance in some way...
Right now this car is a daily driver. Eventually I'll do some HPDE but I'm not planning to be competitive in this car. Just a trackable daily driver. Naturally aspirated with reliable and streetable upgrades along the way.
I should probably mention why I'm doing this in the first place... My transmission actually works great, shifts great and I have no mechanical issues even though my transmission came from a salvage BOSS. What I do have is transmission whine. Not the loudest I've ever heard but not the quietest either. It's annoying. With the Borla exhaust and the side pipes it is pretty easy to ignore it -- but at this point I'm just going overkill. I want to get this car into excellent shape and this is one of the last things that's bugging me. Yeah, it might last forever even with the whine, or it might blow up eventually who knows but... I just want to get it working right. The MT-82 on the V6 never sounded like this...
Clutch replacement advice
Ford is replacing my transmission but do to wear and tear will not cover the clutch. It does appear that I need a clutch despite only 26k miles on a street car. So I am looking at either the mcleod ext or super street pro. If the car is going to remain normally aspirated will the super street...
trackmustangsonline.com
