atrain1975
Guest
At long last, I located the source of an annoying rattle. It is caused by the space between the door sill and the triangular plastic side mirror section. I put some folded up masking tape in the gap and it resolved the rattle. Can somebody recommend a better, permanent solution to the tape? I suppose some sort of black adhesive foam would work. Also, does anybody know whether it is easy / possible to remove the triangular mirror section so that I can put the foam / material in place?
Thanks for any help you can provide!
Alex
Alex
