- 196
- 0
I am about ready to drain the stock DOT brake fluid and add the Castrol stuff. I have heard that the Stock fluid is used in both the brake and clutch systems. If I drain my brake system and replace it, will I have to do the same with the clutch reservoir or will they mix if I don't? I'm a little confused on this and don't want to waste my time by having Castrol mix with the stock fluid if I don't do it correctly.
