Rock Chip, Where can I get?
unrealford
Mustang owner since 84
521
I have a rock chip on my hood decal ( White,on Kona Blue) It stands out really bad. I wanted to replace it then have my 3M clear Defender installed.
Does anyone know if the Hood decals from Ebay are the same texture and shine as original stripe?
I priced one at Ford and the RETAIL price was $ 415.00
Can anyone get me a Ford Price cheaper? Id like to put a Ford original on if I could.
Thanks Shawn..
Heres the Ebay one.
http://www.ebay.com/itm/Mustang-Factory-Style-Vinyl-HOOD-GRAPHIC-Decal-Stripe-3M-Professional-2012-273-/151005213774?pt=Motors_Car_Truck_Parts_Accessories&hash=item23289cb44e
Try this one
http://www.levittownfordsupercenter.com/repair-parts.php
Stripe, Hood, White
Boss 302
$413.08
Your Price : $272.64
There's also tousley ford ( I think that how it's spelled )
No problem, thats what we're all here for.
I'm sure he can custom make one to go closer to hood front (like '69 did) if you'd like, and someone has an avitor in YBM with Boss 302 cut into the hood decal.
Now's your chance to be unique. Or keep it OEM if you like.
The roofs are painted, not decals. Well, I'm assuming both the white and black roofs are done in the same fashion. ;D
contact http://stores.ebay.com/ProMotorStripes/Ford-Mustang-/_i.html?_fsub=2345416012&_sid=29212182&_trksid=p4634.c0.m322
they did my hood decal. No extra charge to design your own if you like. On a 1 to 10 rating. I give them a 10. $44.00 for a new decal is well worth it.
Re: Re: Rock Chip, Where can I get?
Do you feel they have the same glossy look as original?.
Maybe I'll buy 1 Ford one to store and one of these for now, I kniw how Ford makes original equipment obsolete really quick now.
Thanks Shawn..
Heres the Ebay one.
I would try some touch up paint first, before replacing the entire decal. Rock chips are going to happen, this probably won't be the last one.
The only differance between the aftermarket is...... OEM decal is one peice clear vinyl with the backside painted along with the pin stripe. anotherwords when you remove the OEM decal the entire decal comes up even the pin stripe. Aftermarket decals have pinstripe seperate on the same sheet. As for looks (glossy) the finish was the same. The beauty is...for the cost of the decal you can change it to change the look several times and still not cost as much as the OEM. I went from Gloss Black to Matt Black to Coustom Decal to No Decal to ordering a templet to paint the strip on. all these decals and was under $200. your call.
