S197 Mustang Steering Parts:
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
2011 Mustang Steering column (minus PATS receiver). Includes column and one key, upper and lower (engine) steering shaft, turn signal stalk, and firewall bearing/seal assembly. Steering lock has been removed for racing use. $80
NRG short steering hub adapter (6 bolt / sparco 2.75" pattern) - NRG SRK-175H - $75
1" 2.75" x 6 spacer, gold in color with bolts - $10
NRG Steering Wheel Quick release - Gen 2.5 (with 2 contacts for passthrough) - Red Anondize- RK-250RD - $75
All of it? $220, at that point you have a setup that places the wheel where the oem one was, just select your wheel of choice. The bright red and gold release optimizes visibility and safety should a third party need to disconnect the wheel.
790281c844db09efe7ebce8710bdc6a8.jpg641e0f0d6dbae44dcdba072a793d51f0.jpg905bdac894f1311b6bf3a693e520c7c0.jpg8920b96604244fe386dd149e8f4a3583.jpg854e00e505baf8c763f7584b0f7c0d17.jpgbf3b31e6ea18b06427272adbff991753.jpg78cfe36aafa2a895d153a81d18ce89fb.jpg
