S197 SCCA CAM-C spoiler?
hopefully this is the right forum for this. i have a 2007 Shelby gt(glorified gt i know) ive had for years and recently got into scca. im currently in the process of giving it a fairly substantial overhaul. im currently working my way through the aero on it...finishing up a 6 inch(from body perimeter) splitter for it and want to focus on the back next. CAM-C allows for a spoiler to be added that doesnt exceed 10 inches in any direction from the body. ive found a few good examples including terry fair of vorslags 2011 GT that have made use of large spoilers and was hoping to get some input on making my own and how effective they are. currently my plans to use 1/8 inch (may need thicker)6061 aluminum and reinforcing it as needed. my biggest question really pertains to the angle of the spoiler. terry's was set at i believe 65 Degrees which seems extremely vertical. i know in scca events speeds rarely exceed 75 so im wanting to maximize my down force for that speed and below, i figure with the use of vortex generators i can pull the airflow farther down the back window. its my understanding(which may likely be wrong) that spoilers produce the majority of their down force on the outside, i figure if i can pull the airflow further down i can make use of more of the center area of the spoiler. im very much new to the airflow game.
quick details my car shares a lot of similarities to terry's 2011 gt early in its life, its currently running 430rwhp N/A. the rear has been widened to accept 345/30r19's. fronts still have 275s but will be widened too in the future.
any help would be greatly appreciated.
above is a good example of what im wanting to build. the fabrication shouldn't be an issue. but the angles seem steep.
Great question!
I think you’re on the right path to maximize downforce given your class restrictions.
What I would do is find the angle from the top of the back window to the back edge of the trunk lid....then mount the 10” spoiler exactly perpendicular to that angle.
I think the VGs are a good idea for your application. Though I would test the flow patterns over the spoiler with and without the VGs...even if just to see how they affect the (attached) flow on the deck lid and spoiler. By test, I would use water droplets (or color tinted oil if you don’t mind the cleanup) and video/pics before and after.
You are correct about the outer surfaces of a typical spoiler or low wing setup creating the majority of downforce. This is because the fastback angle of the rear sail panels promote two large vortices that spill over its top edges.
Hope that helps and I’d like to see your testing and installation. And welcome to TMO!
Dave_W
683
846
Good basic info on rear spoiler design from GRM's CAM effort:
The thing to remember is that the spoiler itself isn't creating the downforce, it's the backed-up air that the spoiler is holding on the trunk deck that's pushing the car down.
That’s somewhat true of most spoilers but not all. At the opposite extreme are the flat ones like pro-stock drag racers which do not ‘back up’ the air at all, and just use the low pressure wake to generate downforce.
Nice article.
