Tire wear and temps are higher on the inside half of the tire compared to the outside, even with 2.6° camber.
What are your toe settings? 0 toe should result in minimal inside wear. Also, uneven temps may be due to improper pressure. If one side is higher then pressure is probably too low.
Any reason why 19 vs 18? I always found that there are more tire options in 18. The 18s still fit over the Brembos...
I hear this everywhere. Riddle me this:
My car has MM (looking) camber plates, Howe extended ball joints, and a MM K Member with raised LCA pickups. Max camber is 2.6°, ride height is low but not slammed (26.75" with a 26" OD tire) and control arms are level.
Tire wear and temps are higher on the inside half of the tire compared to the outside, even with 2.6° camber. Dare I say the camber curve is pretty effective and I don't need any more camber? Or am I being a weeny and there's actually more steering input that can be dialed in?
For me...19's primarily because the car has 3.73's, and I want to preserve as much speed as possible at the top of 2nd until I swap the gears and diff some time down the road (autocross car, not track car).
Right now, I think my top candidate for rolling stock is 19x10.5 ET45 which I think should fit a 285/35 RE71R with no spacer (or may need 3-5mm). I think that allows me to grow to a 305/30-19 [Rival 1.5 or RE71R] when I am ready to do extended studs and bigger spacers, without having to buy another set of wheels.
Anyone have experience running 19x10.5 ET45 with either of these tires? How much spacer is needed?
[Suspension setup is Koni Sports, MM plates, and BMR Handling springs...]
My mind is blown. All this time I thought the way to speed was spreading temp/wear across the tire.
Thanks for the info
Would depend on what wheel you are looking at. I run 20x10.5 ET45 at all 4 wheels with 285/35/20 PSS tires and had to use a 3mm spacer up front to clear the Brembos but I would guess you might not need a spacer with the regular brakes.
As for 305s on a 10.5 ET45 wheel, I tried 305/30/20 PSS and even 295/30/20 PSS and got rub. I even had 3mm shaved off the hub side of the wheel and still got rub. Now the PSS runs pretty wide and these tires would be 1/2" taller at the top side than the 305/30/19 but my car isn't exactly slammed - I think your BMRs might actually sit the car lower than mine is set up. If I were going to go with 10.5 wheel again, I would want ET50-52 for the back.
They should fit. I am using 19x11 +50 wheels with a 25mm spacer in front. I have done this setup on another car too, Mine has JRi struts and the other has KW.
But, unfortunately, there is no single universal answer. I had a set of Vorshlag fitment Forgestars that required a spacer in the front to clear my particular strut setup at the time..not Vorshlag's fault, just a stack up of what I had on my car at the time.
Spacers are no issue, especially when it is a matter of when, not if, the stock front hubs will fail and the Ford Racing ones are so cheap with the long studs in them already.
DaveW
Once a driver starts thinking about another set of rims I immediately want to suggest keeping their old rims and use the new rims/tires to the maximum effect. You have the tires and wheels to drive around on, but once you want to go to the track or autocross, you can now open yourself to a World of choices. Your rims on the Stang are paid for, likely the rubber on them , and often they are in good shape for just cruising. Now you have the chance to get your new rims/tires and you can be way more decisive about maximum stick at the track/autocross. For example, a set of 18x11s ( Apex) , with a set of BFG Rival S 1.5s in 315/18s means a mean mother running in a CAM Class, auto crossing. Solid tire for the track, or heck, wing it for 315/18 gforce R1s and more stick on a road course. Sure there are other choices , but this is a solid example, because three tires in the back seat, and one in the trunk is super easy with the Mustang --- jack, tools, and even duffel bag with clothes and more is a cinch.
Common practice seems to be to sell the old rims ( they bring squat) and if the rubber is still on said , it is a giveaway. Keeping them makes so much sense and was super common with a bunch of folks years back. Something to consider????
