move the batt to the back along with the DS and exhaust and a lighter rad support and the weight should be back to normal or really close front to back I would thinkJonW said:Justin said:an alum driveshaft and lighter mufflers would get you there if not close. to shave that 50 back off.JonW said:If the KB indeed only adds 50 pounds, then that would be the best of both worlds. Plus, if you were really serious, you could replace some front end components with aluminum or carbon fiber and probably lose half of that 50 pounds.
Yes, but you need the weight off the front of the car if you want to offset the blower.
