She's smoking from the right bank
@TMSBOSS be safe out there and I hope it's nothing serious.
899
546
Breather can was almost dry.
Leaving on business for about a month. No time to tear into it now.
Any suggestions where to pickup a short block?
If your inspection finds a failure, I would recommend an Aluminator short block:
https://performanceparts.ford.com/part/M-6009-A50NAA
Don Woods:
https://fordracingpartsbydonwood.co...LtIA7xPnCZ0mGx8R06en3xf6hfABW2g_RzhoCgDfw_wcB
Levittown Ford:
http://www.levittownfordparts.com/ford-racing-coyote-aluminator-short-block-p-5185.html
I would also call Tasca and AutoNation Ford White Bear Lake for pricing.
680
215
You also have the option of a Boss short block available from Ford Performance...
Then you don't have to worry about installing heads or anything. This is probably the fastest TV dinner solution...
7,556
5,291
Guys, thanks for the assists and encouragement. Something you got to know, I actually get as much enjoyment out of working on cars as I do driving the boss. So, except for the financial down side, this ain't so bad.
I will be out of the house for the next month or so. When I come home, I'll do a dry compression test, wet compression test, inspect the plugs and scope the cylinders. If the block is toast, which I doubt, I'll go the aluminator route. If I have broken rings, I'll make the call of the aluminator or rebuild the original block....just bigger, stronger and of course faster.
When you add up the cost of HD Pistons, rings and oil pump the aluminator looks good. I could also then save the original boss block and rebuild to original specs.
Regardless, I'll look under her skirt and see what I see. Yes, I will peak and tell. More to follow.
Just stay away from MMR if you are in bad shape and have to go down the rebuild route. Aluminator short block from any good Ford retailer is highly recommended. Hopefully nothing serious.
Tracy, I hope it's something simple. Keep us updated.
Right side is where cyl. 8 is (unless, you have an x-pipe) which is known to overheat sometimes.
7,556
5,291
Buying a Scope to look at the cylinders.
Strange thing is she runs great, no noise, smooth as before. I wonder if I did not lift a head and blow a gasket?? Water temp at 240. No limp mode.
Regardless, she will be looked after and made stronger. Unfortunately, The Mustang Roundup is not looking like a possibility this year.
