Shifting problems at Pitt
cobrarob
11 Shelby GT500
541
126
new york
Hey guys. I have 11’ gt500 with stock clutch with 31,000 miles. Started not able to downshift to 3rd then couldn’t up to 4th when she got hot on track.Clutch pedal travel felt very different and strarted grabbing of floor. Had some brake fluid underneath. What choices on upgrades are recommended?
Not full on track car, ocassional cruze on Sundays Thanks
JDee
Ancient Racer
1,668
1,774
5 miles from Mosport
Stock clutch causing shifting issues is common, causing exactly the symptoms you describe. Aftermarket clutches are the cure, I have an Exedy Hyper Single which solved all those issues but with the GT500 you might need more than that. I'm sure other guys will chime in on recommendations for that car.
