- Thread starter
- #41
4 / 8 compression/ rebound is what I found mcs says to start with.
I can't help you with the MCS settings, but I think you'll get it sorted out quickly.
Found the book on Amazon for $25. Be here Sunday !For any double adjustable that we are starting with I set the rebound about 1/3 of the range up from full soft (fast), and the compression right in the middle of the range. So much changes between bushings (sometimes very tight bushings), bars, tires and driving style, that it's hard to say "THIS" is the right settings.
Also, if you are in the weeds on setting them up, I highly recommend Neil Roberts book, "Think Fast". He uses plain language and simple tests to help with setup and improvements.
